12 years agoInterfacing between Simulink and Altera Board
Hi guys. I want to ask about interfacing between Simulink and Altera board. I never used this before. I have designed my model using Simulink block. I want convert it to hdl code using hdl code...
12 years agoIf you need to interface to an SDRAM, you'll need to drop in an SDRAM controller yourself. You can get the IP from Altera, but you'll need to connect it to your generated HDL.
