9 years agointerfacing a pcie daughter card to development board
Hello all, I am new here and I'm trying to find out if what I want to do is easy, hard or even possible.
I want to use an Altera FPGA development board (not yet purchased) to directly control an off the shelf PCIe card. Is there a board that has a PCIe slot already built in? If not does anyone know of an adapter to connect the PCIe card to any of the standard inputs on the FPGA board? Then if I can connect to the PCIe card, is there a quick way to set up the interface? Something pre-defined and available from Altera or elsewhere? As you can see I am just starting with this project any information or tips would be a big help. Thanks!6 Replies
--- Quote Start --- Thanks, this sounds perfect! --- Quote End --- No problem - glad you found it useful. Good luck with your project! - Altera_Forum
--- Quote Start --- You can also buy a PCIe root port FMC card like below, which gives you more options for which dev kit to buy. http://www.hitechglobal.com/fmcmodules/fmc_pciexpress.htm --- Quote End --- Thanks, this sounds perfect. - Altera_Forum
http://www.hitechglobal.com/fmcmodules/fmc_pciexpress.htm - Altera_Forum
Thanks Dave I'll check those out.
Take a look at some of the SoC development kits, eg.,
https://www.altera.com/products/boards_and_kits/dev-kits/altera/kit-arria-v-soc.html Bottom left is a PCIe slot. Not for a large one ... but maybe that is enough for you. Cheers, Dave
