15 years ago
interface code
Hello friends,
I have 2 circuits viz cir1 and cir 3. Now i want to link these 2 circuits via an independent entity say-cir2. In other words cir2 will act as a bridge between cir1 and cir3. i have independent vhdl files for both cir1 and cir3 i.e cir1.vhd and cir3.vhd. How do i write the code for cir2? How can i call the 2 circuits i.e cir1 and cir3 via the cir2 code? Pls assist me.
Vinod.
    architecture struct of cir2 is
    signal a,b,c : std_lgoic;
    begin
    cir1_inst : entity work.cir1
    port map (x1,y1,z1, a,b,c); --- sir pls note this step. Where can i map a,b and c ?
    cir3_inst : entity work.cir3
    port map (a,b,c, x2,y2,z2);
    Dear Sir,
    Thanks again. i shall show the code that i used. There are no errors on comilation. but on simulating no waves are generated
    cir1.vhd
    library ieee;
    use ieee.std_logic_1164.all;
    entity cir1 is
    port(a,b,c:in std_logic;
    x,y,z:out std_logic);
    end cir1;
    architecture behavioural of cir1 is
    begin
    x <= (not a and not b) or (not b and not c) or (a and not c);
    y <= (not a and not b) or (not a and not c);
    z <= (not a and not b) or (a and b);
    end behavioural;
    cir3.vhd
    library ieee;
    entity cir3 is
    port(x,y,z:in std_logic;
    p,q,r,s:out std_logic);
    end cir3;
    architecture behavioural of cir3 is
    begin
    p <= (not z ) or (not x and not y and z);
    q <= (not x and not y and z) or (x and y and z);
    r <= (not x and y) or (x and not y and not z);
    s <= not x;
    end behavioural;
    cir2.vhd
    library ieee;
    entity cir2 is
    port(x1,y1,z1:in std_logic;
    x2,y2,z2:out std_logic);
    end cir2;
    signal a,b,c,p,q,r,s:std_logic;
    begin
    port map (x1,y1,z1,a,b,c);
    cir2_inst : entity work.cir2
    port map (a,b,c,x2,y2,z2);
    end struct;
    my cir2.do file is also pasted
    quit -sim
    vsim cir3
    view wave
    add wave a
    add wave b
    add wave c
    add wave p
    add wave q
    add wave r
    add wave s
    force a 0 50,0 100,0 150,0 200,1 250,1 300,1 350,1 400 -repeat 400
    force b 0 50,0 100,1 150,1 200,0 250,0 300,1 350,1 400 -repeat 400
    force c 0 50,1 100,0 150,1 200,0 250,1 300,0 350,1 400 -repeat 400
    run 800ns
    .I don't get any o/ps.
    Again , thanks for ur time. I really appreciate it sir.
    Vinod Karuvat.
    you need to force x1,y1,z1 as these are the top level inputs. Not a/b/c. a,b,c are just interconnect wires between two entities. You are not seeing any waves because x2,y2 and z2 are the outputs. p,q,r,s do not exist in cir2, they only exist in cir3
    Wow. i did not even think about that sir. but is there any way i can test this whole circuit. in other words , i just provide the i/ps a,b and c and i get the o/p p,q,r and s?
    Vinod.
    you would be doing that by forcing x1,y1,z1. I think you are confusing yourself by calling the inputs to cir2 x1,y1,z1 when the inputs to cir1 are a,b,c. Maybe change the names of the top level inputs to a,b,c and the internal signals to x,y,z
