15 years agointerface code
Hello friends, I have 2 circuits viz cir1 and cir 3. Now i want to link these 2 circuits via an independent entity say-cir2. In other words cir2 will act as a bridge between cir1 and cir3. i ha...
15 years agoDear Sir,
Thanks again. i shall show the code that i used. There are no errors on comilation. but on simulating no waves are generated cir1.vhd library ieee; use ieee.std_logic_1164.all; entity cir1 is port(a,b,c:in std_logic; x,y,z:out std_logic); end cir1; architecture behavioural of cir1 is begin x <= (not a and not b) or (not b and not c) or (a and not c); y <= (not a and not b) or (not a and not c); z <= (not a and not b) or (a and b); end behavioural; cir3.vhd library ieee; use ieee.std_logic_1164.all; entity cir3 is port(x,y,z:in std_logic; p,q,r,s:out std_logic); end cir3; architecture behavioural of cir3 is begin p <= (not z ) or (not x and not y and z); q <= (not x and not y and z) or (x and y and z); r <= (not x and y) or (x and not y and not z); s <= not x; end behavioural; cir2.vhd library ieee; use ieee.std_logic_1164.all; entity cir2 is port(x1,y1,z1:in std_logic; x2,y2,z2:out std_logic); end cir2; architecture struct of cir2 is signal a,b,c,p,q,r,s:std_logic; begin cir1_inst : entity work.cir1 port map (x1,y1,z1,a,b,c); cir2_inst : entity work.cir2 port map (a,b,c,x2,y2,z2); end struct; my cir2.do file is also pasted quit -sim vsim cir3 view wave add wave a add wave b add wave c add wave p add wave q add wave r add wave s force a 0 50,0 100,0 150,0 200,1 250,1 300,1 350,1 400 -repeat 400 force b 0 50,0 100,1 150,1 200,0 250,0 300,1 350,1 400 -repeat 400 force c 0 50,1 100,0 150,1 200,0 250,1 300,0 350,1 400 -repeat 400 run 800ns .I don't get any o/ps. Again , thanks for ur time. I really appreciate it sir. Regards, Vinod Karuvat.
