open01
4 years agoInterconnect delay with Input2reg
Hi All,
I am using the CycloneV device.
I use logiclock to fix placement position in the same LAB. But when I set different input delays, routing at the same position produces different results. ...
sstrell
4 years agoThat's kind of the point of set_input_delay. The larger value you give for -max, the more time the router has to play with, so it may add more routing between the I/O and the input register. What is your goal here and what does your .sdc look like?
open01
4 years agoHi sstrell,
Thank you for your help,
I have 12 different data input from 12 I/O pads, and they will enter 12 different input first register respectively.
I use logiclock to keep all registers close to their own I/O pads.
But the data delay of each path has a big gap, I want to know how can I make their values closer.
Best regards.
