JPrig
5 years agoInter-board TTK fails
I have set up a TTK link between a board with a Cyclone V and another board with Arria 10. I have a stable CDR lock in both directions but when I start data transmission, it fails in both direc...
CheepinC_altera
5 years agoHi Julia,
As I understand it, you observe some problems when trying to perform a link BER test between CV TTK and A10 TTK. Based on your description, one of the possible reasons might be the patterns between the CV TTK is not directly compatible with the A10 TTK. Sorry as I do not have the visibility into data transmitted from the TTKs but this is just a suspect.
As a workaround, you may create simple test design with PRBS generator and checker. Run the BER test and monitor using signaltap. You may in parallel use the TTKs to dynamically tune analog settings on both device and monitor the BER in signaltap.
JPrig
5 years agoHi,
thanks for your reply. We will try to proceed as you suggest.
Julia
