KJalte2
7 years agoIntelFPGA の 10M04SCE144I7G のFIT値を教えてください。
- 7 years agoHi, Based on my understanding, the question you asking is about the FIT value for intel FPGA 10M04SCE144I7G device, am I right? If yes, the failure-in-time rate (FIT rate) for the devices within the same family with the same process technology will be very similar and can be used for devices that not explicitly in the Reliability Report. Max 10 products are fabricated on 55nm process technology, so the FIT rate of Max 10 product is 31.4. The failure rates are calculated on a product family basis and the equivalent hours are calculated at a typical use condition of VCC nominal in a 55C still-air-ambient or 70C junction. You can refer to the link below for more information: https://www.altera.com/en_US/pdfs/literature/rr/rr.pdf Thank you
MEIYAN_L_Intel
7 years agoHi,
Thank you
