StefanoMarsi
3 years agoIntel Monito Program FAILS in manage header files.
After several test I realize that if you need to manage separately source files (.c) and header files (.h) including both in your project using Intel Monitor Program, there is no way to distinguish b...
StefanoMarsi
3 years agoThank you for your feedback
Actually, I'm using Quartus 22.1 (but this should be quite independent after the .sof generation)
and Intel Monitor Program 21.1.
The problem is limited in the auto-generation of the "amp.mk" provided by MP that does not distinguish between source files and header files. With the suggested workaround everything seems to work properly.
I leave this note to help other users and hoping the developers of MP would provide a correct version for the feature
