8 years agoIntel HLS compiler issue
I've been using the Intel HLS compiler for a bit now and have gone ahead and started using the tool beyond the examples provided, but I ran into an issue. Typically the software (x86) and the verilog match up. However in this instance I got a discrepancy. At first I thought it was due to using random to generate values, but as I don't change the seed the pattern should be the same across runs. Here's a small snippet: int main(){ int ret; bool same; for(i=0;i<100;i++){ data = rand() % 10; ret = comp_func(data, &same); printf("ret : %d same?: %s\n",ret,(same)?"yes":"no"); ... } ... } Is this okay that there exist discrepancies between the two versions? Thanks, EliasNo RepliesBe the first to reply
