Muralidhar_S_Intel
6 years agoIntel HLS compiler - Hitting Fatal Error when linking export_tramp.so library
I am trying to get the "counter" example from the Intel HLS tool to compile and work . I have done all the setup appropriately and I am using the quartus and HLS version 19.4. After installing the ...
MEIYAN_L_Intel
6 years agoHi,
May I know the information as below for further investigate:
1. Modelsim edition and version
2. It look like you are using gcc v5.4.0. please confirm
3. Is there any other version of Quartus / HlS in this machine?
Also, do you have install the 32bits of the libraries? This is because Modelsim require all 32bits of libraries to be install.
- Muralidhar_S_Intel6 years ago
Thanks. Here is the information.
- ModelSim - Intel FPGA Edition - Part of the Quartus 19.4 package.
- Yes. The GCC version is right. It's been built for the HLS from the 19.4 package.
- No, this i the only version.
I believe I have installed all the 32 bits of the libraries, when I tried to compile GCC and Modelsim. Packages like libc6-i386, gcc-multilib, g++-multilib etc.
