Intel FPGA Questor simulation doesn't see lower level components
- 3 years ago
Ah! I think there is a slight different between Questa and Modelsim. The double-click on the processor1 in Modelsim provide full visibility into every aspect of the design (+acc=<full>). While Questa only provide visibility to ports only. (+acc=p)
Reference on -voptargs: https://users.ece.cmu.edu/~jhoe/doku/doku.php?id=a_short_intro_to_modelsim_verilog_simulator
I am not too sure why the changes though, people from the Siemen probably know this.
A few ways to get full visibility are:
1) Enter below command to get the full visibility. By adding -voptargs=+acc .
vsim -voptargs=+acc work.processor1
2) Right-click the processor1 and select simulate. Instead of double-click.
Richard Tan
Hi Helen,
Do you got the same behaviour with Modelsim?
Could you share the testbench or screenshot here so I can see what goes wrong?
Correct me if I am wrong. I do not see a testbench in the design attached previously.
Richard Tan
ps. Please be informed that there will be delay in response in the following week due to holiday season.
- Helen53 years ago
Hi Richard,
No, their was no problem when ModelSim-Altera was used as the simulator.
I don't have a testbench for this project. Here is a script is used as the macro file (.do).
add wave -position insertpoint \
sim:/processor1/output_data \
sim:/processor1/inputdata
sim:/processor1/clk
sim:/processor1/reset
sim:/processor1/b2v_dataPathInst/b2v_Regs/registers
sim:/processor1/b2v_RAMInst/mem_table
force -freeze sim:/processor1/clk 1 0, 0 {50 ps} -r 100
force -freeze sim:/processor1/reset 1 0
force -freeze sim:/processor1/reset 0 300
force -freeze sim:/processor1/inputdata 10#99 0As Qsim cannot see the lower level components, so the commands such as sim:/processor1/b2v_dataPathInst/b2v_Regs/registers will cause an error message.
Basically to simulate the project, a clock and high active reset are needed, inputdata is not essential.
