Saikiranbelana
3 years agoIntel Devstack-OpenCL unable to detect PAC Cards
Intel Development Acceleration Stack for OpenCL is not detecting the Arria 10 PAC Cards on our server. It's looking for PAC drivers which cannot be found at the OpenCL_BSP installation path.
The Ca...
Saikiranbelana
3 years agoyes, I have followed the same steps. The problem occurs the same.
The following is the output when I try to uninstall and reinstall the BSP:
server2@ubuntu:~$ aocl uninstall Do you want to unset the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] Y aocl uninstall: /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp is not installed, no need to uninstall. server2@ubuntu:~$ aocl install Do you want to setup the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] n Please specify a directory to setup FCD: /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/ aocl install: Setting up the FPGA Client Driver (FCD) to the system. This process may require admin privilege Install the FCD file to /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp aocl install: Adding the board package /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp to the list of installed packages Installing the board package driver to the system. aocl install: Running install from /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec server2@ubuntu:~$ aocl list-devices -------------------------------------------------------------------- Warning: No devices attached for package: /opt/intelFPGA_pro/quartus_19.2.0b57/hld/board/a10_ref --------------------------------------------------------------------
