Intel Arria10 GX Development Kit - DDR3 example design - traffic_gen_fail
Hi ats52,
"If I suppose you have an Arria 10 GX Development Kit board, the project I attached works fine on your board?"
- Currently we have some hardware limitation to test the design. Thus, I cannot test the design you provided.
"As far as I've looked into the installer package of arria10GX_10ax115sf45_fpga_v22.4.0_v1.1.zip, it looks only SOF files are included for BTS items, the project designs are not. Is it possible to get the project design for BTS of DDR3? Since BTS and the example design test for DDR3 make difference, I hope I will be able to find some clues if the project is available"
- You can use the design from "arria10GX_10ax115sf45_fpga_v22.4.0_v1.1.zip\arria10GX_10ax115sf45_fpga_v22.4.0_v1.1\examples\memory\PRD\qts_ddr3_x72_1066MHz" to run the test.
- I think it's similar to BTS design.
Adzim
Hi AdzimZM
Thanks for the information about the BTS design. Indeed it is there in the archive.
I have compared the EMIF IP configuration between the generated example design and the DUT in BTS.
There are not that many parameters different from each other, however they does make difference.
I have applied to the following configuration parameters of BTS to the EMIF DDR3 IP in the example design, in addition to the design itself differences (address width, ECC enable/disable) etc.
| Tab | sub category | parameter name | emif_0 (example design) | ed_synth_dut_0 (board support test) |
| Mem I/O | Memory I/O Settings | ODT Rtt nominal value | ODT Disabled | RZQ/2 |
| - | - | Dynamic ODT (Rtt_WR) value | RZQ/4 | Dynamic ODT off |
| FPGA I/O | Address/Command | Output mode | 12 mA | 8 mA |
| - | - | Slew rate | unset | Fast |
| - | Memory Clock | Output mode | 12 mA | 8 mA |
| Mem Timing | Parameters dependent on Speed Bin, Operating Frequency, and Page Size | tRRD | 6 | 7 |
| - | - | tFAW | 25.0 | 35.0 |
| - | Parameters dependent on Density and Temperature | tRFC | 160.0 | 260.0 |
Now I got the successful result with both local_cal_success and traffic_gen_pass.
Thank you for your support.
