11 years ago
Instruction on multiple clock cycle
Hi everyone !
I'm working on a project where I generate a timestamp through a counter that is incremented by 1 every clock cycle.
The thing is, every time I load the timestamp value in my buffer, the value is not incremented by 1 but by the size of my timestamp, which is 8 bits.
So I will have my first value at 0 and then the second value at 7 the third one at 15 and so on ....
I need to increment my counter no every clock cycle, but every 8 clock cycles, in order to solve the problem.
So i would like to know if such a thing is possible, and if so, how could I do it ?
I've tried to do it with a loop or with some wait statement, but so far nothing worked.
Here is the code of my counter :
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY counter IS
PORT(
clk_i : in std_logic;
count : out std_logic_vector(7 DOWNTO 0)
end counter;
ARCHITECTURE rtl OF counter IS
SIGNAL s_count : STD_LOGIC_VECTOR(7 DOWNTO 0);
begin
process (clk_i)
begin
if clk_i'event AND clk_i = '1' then
s_count <= s_count + 1;
end if;
end process;
count <= s_count;
end;
Hoping some of you can help !
Thanks in advance.
Cordially,
David.
    Well my counter will be the timestamp of my system. It could have been a clock as well.
    Then I'll write it in the firsts pixels of my image.
    I have a 16MHz clock, and my video is at 30 frames per second. At that rate I have more timestamps than I have new images, avoiding the problem of having the same timestamp for several images.
    My micro-processor will pick a timestamp every time an image is refreshing.
    The thing is my timestamp is serialized to be send on my slave board and then parallelized to be treated.
    I need to increment my counter no every clock cycle, but every 8 clock cycles, in order to solve some parts of the problem.
    How do you read the counter as timestamp. You may not catchup with its speed. Normally people read timestamp from system clock.
    Thank you I changed It, my mistake.
    It's 32 bits on the board, but I put 8 bits in simulation in order to simplify the results
    your s_count is 32 bits. Your count is 8 bits. How did it compile?
