17 years agoInstantiation of DMA on SOPC Builder
Hello, I have a question about instantiation of DMA in SOPC Builder. When you add the DMA controller, you must connect the read master and the write master. For me, I can connect them to any wh...
17 years agoThe instruction master is only capable of reading instructions (code) from memory. It's not capable of write accesses since that's what the data master is for. As a result if you don't plan on placing code in a particular memory then there is no need to connect the instruction master up to it.
