17 years agoInstantiation of DMA on SOPC Builder
Hello, I have a question about instantiation of DMA in SOPC Builder. When you add the DMA controller, you must connect the read master and the write master. For me, I can connect them to any wh...
17 years agoeach white dot means that this master can not reach the slave.
if you change such a dot to a black dot, then the master can access this particular slave. you must specify the allowed / possibel connection the read master connects to each possible source the write master to each possible destination but you must enable the controlport slave for the nios data master otherwise you wont be able to control the dma by software.
