9 years agoInstantiate Max 10 ADC in VHDL
I'm sure this has been covered, but I can't seem to get Quartus to make the connection. I have a design that is 99% straight VHDL, but I need to monitor a couple of power supplies, so I routed scaled...
9 years agoOk, well you were right. I missed something subtle in the instantiation file because I was used to doing it the regular way.
Using component instead of entity fixed it: U_ADC : component lsm_emulator_adc port map ( adc_pll_clock_clk => ADC_Clock, -- adc_pll_clock.clk adc_pll_locked_export => ADC_Locked, -- adc_pll_locked.export clock_clk => SIM_Clock, -- clock.clk command_valid => Command_Valid, -- command.valid command_channel => Command_Channel, -- .channel command_startofpacket => Command_SoP, -- .startofpacket command_endofpacket => Command_EoP, -- .endofpacket command_ready => Command_Ready, -- .ready reset_sink_reset_n => Reset_n, -- reset_sink.reset_n response_valid => Response_Valid, -- response.valid response_channel => Response_Channel, -- .channel response_data => Response_Data, -- .data response_startofpacket => Response_SoP, -- .startofpacket response_endofpacket => Response_EoP -- .endofpacket ); I'm not sure if including the library made a difference or not. It's still in the HDL, but it may not be necessary. Thanks for the hint!
