9 years agoInstantiate Max 10 ADC in VHDL
I'm sure this has been covered, but I can't seem to get Quartus to make the connection. I have a design that is 99% straight VHDL, but I need to monitor a couple of power supplies, so I routed scaled versions to the Max 10 ADC. I built a Qsys component for a simple ADC-only core and tried to instantiate it in my VHDL design, but I keep getting an error that an entity was used without being declared.
Now, I get that everything Quartus is generating is in Verilog, so I verified the case was correct, but still no dice. I know Quartus is aware of the ADC core because I see the messages about its generation during the build. I named the core "lsm_emulator_adc", and it has a corresponding "lsm_emulator_adc.qsys" file which I brought into Quartus. I then mapped it in my HDL using a variety of methods, but at the moment: U_ADC : entity lsm_emulator_adc.lsm_emulator_adc_modular_adc_0 port map ( adc_pll_clock_clk => ADC_Clock, -- adc_pll_clock.clk adc_pll_locked_export => ADC_Locked, -- adc_pll_locked.export clock_clk => SIM_Clock, -- clock.clk command_valid => Command_Valid, -- command.valid command_channel => Command_Channel, -- .channel command_startofpacket => Command_SoP, -- .startofpacket command_endofpacket => Command_EoP, -- .endofpacket command_ready => Command_Ready, -- .ready reset_sink_reset_n => Reset_n, -- reset_sink.reset_n response_valid => Response_Valid, -- response.valid response_channel => Response_Channel, -- .channel response_data => Response_Data, -- .data response_startofpacket => Response_SoP, -- .startofpacket response_endofpacket => Response_EoP -- .endofpacket ); I even tried declaring the component to see if that would resolve it, but so far no. Can anyone help me figure out what I am doing wrong, or show me how to connect to the Max 10 ADC from a VHDL project? Thanks!2 Replies
Ok, well you were right. I missed something subtle in the instantiation file because I was used to doing it the regular way.
Using component instead of entity fixed it: U_ADC : component lsm_emulator_adc port map ( adc_pll_clock_clk => ADC_Clock, -- adc_pll_clock.clk adc_pll_locked_export => ADC_Locked, -- adc_pll_locked.export clock_clk => SIM_Clock, -- clock.clk command_valid => Command_Valid, -- command.valid command_channel => Command_Channel, -- .channel command_startofpacket => Command_SoP, -- .startofpacket command_endofpacket => Command_EoP, -- .endofpacket command_ready => Command_Ready, -- .ready reset_sink_reset_n => Reset_n, -- reset_sink.reset_n response_valid => Response_Valid, -- response.valid response_channel => Response_Channel, -- .channel response_data => Response_Data, -- .data response_startofpacket => Response_SoP, -- .startofpacket response_endofpacket => Response_EoP -- .endofpacket ); I'm not sure if including the library made a difference or not. It's still in the HDL, but it may not be necessary. Thanks for the hint! - Altera_Forum
In the parameter editor (Qsys) from the Generate menu, did you look at the instantiation template? That should help you out.
Can you post the component declaration and the exact error messages you're getting including messages just before the error?
