12 years agoinput[12] bit width for dac in squre root calculation.
in a square root operation of 4sinwt using altfp_sqrt block . i have taken 32 bit input and 32 bit output and clock was system clock from pin 28. so program compiled succesfullt. now for showing it i...
12 years agoIf you can afford to generate the square root 1 bit (of result) per clock (maybe 2 clocks at high clock rates), then the 'schoolboy' method works very well in binary and will probably use a lot less logic.
For 12 bit input I think you could just chain 6 subtract + conditional-mux blocks...
