16 years agoInout questions in testbench
Hi to all :) after doing a certain number of exercizes, about a PWM and an Encoder, I'm doing the first example of a simple PLD. In this example, I use two bus from a DSP: an address bus, and a da...
16 years agoWhat you see in the simulation depends on your logic design and on your test bench.
What you'll see in the simulation will depend on your logic design and whatever it's connected to. So... your testbench should model the real world as closely as needed.
