10 years agoInject SDRAM ECC error on Cyclone V HPS
Is it possible to inject ECC errors at the SDRAM controller on Cyclone V HPS ? These are enabled in the sdr.dramintr register and the status reflected in sdr.dramsts.
I found examples of injecting errors at the cache level and for components that have their own on-chip RAM buffer areas, but the only example I saw for injecting errors at the SDRAM controller used the process of shorting the physical pins of the third SDRAM part on the eval board to corrupt the ECC.No RepliesBe the first to reply
