Initial value setting error
- 4 years ago
Try to use devices Cyclone III, Cyclone IV, Max II, Max V or Arria II instead of Cyclone V. New devices are not supported on vwf waveform simulator because this is legacy simulator which only supported legacy devices and mainly for university program purpose. Or may be you can use modelsim simulator instead of vwf waveform simulator.
Sheng
I'm getting the desired vwf waveform for the code posted above. Check image below:
I think there is no problem with the code given.
File attached: fsm.zip
Quartus version: Prime 21.1 Standard Edition
Sheng
Sorry, I upload a wrong picture above. Here is my vwf waveform.
The "state" pin perform high at the begining. However, you said that the waveform simulation on your computer is correct. I'm wondering if it is because of the setting of my quartus. I just install Quartus these days. By the way, my quartus is version 13.1 web edition. I found that even I use timing simulation insted of functional simulation, there has no delay on the waveform. I'm not sure if there is a problem on the result and I'm figuring out the solution.
