11 years agoInferring two multipliers in one DPS block in verilog/VHDL, Cyclone V
The module dsp1a infers two DSP blocks. Why not one DSP? Is there any way to force synthesiser to use one DSP block? I would like to use Independent Multiplier Mode of DSP block. While the si...
11 years agoHi,
I'm having a similar problem, our design fails to fit with an error about too many dsp elements but it should easily fit when packing 2 18x18 / 3 9x9s in each dsp... I found that by setting the 'Auto pack registers' under fitter settings to Off (the default is Auto i think), the design now fits. it seems like its packing registers in to the dsps before it actually packs the multipliers in... or something... Would be good to get a proper fix as register packing is useful to have on. Hope it helps, Cheers Adam
