11 years agoInferring two multipliers in one DPS block in verilog/VHDL, Cyclone V
The module dsp1a infers two DSP blocks. Why not one DSP? Is there any way to force synthesiser to use one DSP block? I would like to use Independent Multiplier Mode of DSP block. While the si...
11 years agoI am having a similar problem where I have 8 9x9 multipliers and their outputs are fed into an adder tree to get the sum of products.
I was hoping Quartus to use only 3 DSP blocks, where 2 DSPs are in "three independent 9x9" mode and 1 DSP in "three indepedent 9x9" or "two 18x18" mode. However, Quartus manages to use 4 DSPs with 2 sets of cascaded "sum of four 18x18" blocks (2 DSP for each four 18x18). I tried setting a logic lock region which has 3 DSPs and sufficient amount of LUTs for the adder tree, but Quartus complains unable to fit. Hope Quartus can provide more fine-grained controls to users in this case.
