11 years agoInferring two multipliers in one DPS block in verilog/VHDL, Cyclone V
The module dsp1a infers two DSP blocks. Why not one DSP? Is there any way to force synthesiser to use one DSP block? I would like to use Independent Multiplier Mode of DSP block. While the si...
11 years agoHi Luca,
still I have not good news. If I find the solution, I will write it here. Cheers, Jan --- Quote Start --- Hi all, I am facing the same issue of jenii. Both Quartus v14 and v15 does not pack three multipliers 9x9bit within the same DSP block. I tried also with the lpm_mult and altmult instances with no luck. Jenii, have you got any news from Altera? Cheers, Luca --- Quote End ---
