11 years agoInferring two multipliers in one DPS block in verilog/VHDL, Cyclone V
The module dsp1a infers two DSP blocks. Why not one DSP? Is there any way to force synthesiser to use one DSP block? I would like to use Independent Multiplier Mode of DSP block. While the si...
11 years agoyes, exactly. There was no warning or error, except that design was bigger than device. I used 26 independent 8x8 multipliers described in code above, it occupies 26 DSP blocks. Also tried different coding (with/without registers, clock), synthetis attributes, settings, etc.
I would like to infer this: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-v/cv_5v2.pdf , page 50
