11 years agoInferring two multipliers in one DPS block in verilog/VHDL, Cyclone V
The module dsp1a infers two DSP blocks. Why not one DSP? Is there any way to force synthesiser to use one DSP block? I would like to use Independent Multiplier Mode of DSP block. While the si...
11 years agodo you mean that you are using 26 independent 8x8 multiples? did you see fitting error or any other errors? How many DSP blocks are occupied?
