16 years agoinferred multiplier pipelining
Is there a way or attribute to control the pipeline value of an inferred multiplier? It looks like that Quartus will use 1 pipeline only. Thanks in advance
16 years agoTricky is describing register retiming.
what about using the MegaWizard to create an lpm_multiplier, then looking at their multiplier instantion:LIBRARY lpm;
USE lpm.all;
lpm_mult_component : lpm_mult
GENERIC MAP (
lpm_hint => "MAXIMIZE_SPEED=5",
lpm_pipeline => 3,
lpm_representation => "SIGNED",
lpm_type => "LPM_MULT",
lpm_widtha => 20,
lpm_widthb => 20,
lpm_widthp => 40
PORT MAP (
dataa => dataa,
datab => datab,
clock => clock,
result => sub_wire0
); you can see the pipeline parameter here. it looks like its using the internal DSP block registers (i looked at RTL Viewer with an Arria II GX).
