16 years agoIncrease input delay on clock pin - Cyclone 2
Hi, I am currently working on a Cyclone 2 ep2c35F672c6 FPGA and I don't find a solution to the following problem: I have a clock connected to the P2 pin (CLK2 pin) and I need to delay it ...
16 years ago --- Quote Start --- Yes, I found three options related to delays: D1 Fine Delay, D4 Fine Delay and DPCLKp to Fan-Out destinations delay. --- Quote End --- I think these options are not supported in Cyclone families. The relevant options should be "increase/decrease input delay ...". But again, usually it is best to let the fitter manage those delays using the right timing constraints. --- Quote Start --- I have a 1ns tSU parameter for the external device and source synchronous edge-aligned DDR input data... Yes, all are independent unrelated clocks in range 2.5-125 Mhz. --- Quote End --- Multiple fast edge-aligned DDR input interfaces, without PLL, doesn't sound easy. Either way, I'm not sure you are applying the right timing constraints. tSU as an output parameter, normally means clock-to-data delay, and not data-to-clock delay.
