16 years agoIncrease input delay on clock pin - Cyclone 2
Hi, I am currently working on a Cyclone 2 ep2c35F672c6 FPGA and I don't find a solution to the following problem: I have a clock connected to the P2 pin (CLK2 pin) and I need to delay it ...
16 years ago --- Quote Start --- The I/O programmable delay configuration is available at the Assignment Editor. --- Quote End --- Yes, I found three options related to delays: D1 Fine Delay, D4 Fine Delay and DPCLKp to Fan-Out destinations delay. The first two have no effect (maybe because they can't be applied to this pin????) and the last one can't be used since this pin is not a Dual-Purpose clock pin. --- Quote Start --- Why you need that delay? What exactly you want to achieve? --- Quote End --- Have a look in the post attached image... I have a 1ns tSU parameter for the external device and source synchronous edge-aligned DDR input data. I thought that with a bit more delay on the clock line these settings could actually work... I assumed that by constraining tSU, Quartus would enable the delay paths automatically, but it doesn't. --- Quote Start --- You mention you need it on eight different pins. What is the relation between those 8 signals? Are they 8 different clocks? --- Quote End --- Yes, all are independent unrelated clocks in range 2.5-125 Mhz.
