16 years agoIncrease data rate
In my design, there are 8-bit parallel data output from the FPGA. I don't have a problem with its TimeQuest analysis. However, the setup slacks for the 8-bits with respect to the clock are very diffe...
16 years agoHi Guys,
Thank you very much indeed for your replies. 1. I did use "Fast Output Registers". 2. The setup slacks are all positive. 3. The longest delays are caused by IOOBUF delays. 4. I think that the timing difference of data matters. The big the timing difference is, the slower the data rate will be. 5. I did use one VREF pins for the data. After I moved the data bit to a non-VREF pin, there is a significant improvement. Now the max time difference among the data bits is less than 0.3ns. I really appreciate your suggestions. Many thanks and best regards, Bcao
