12 years agoIncorrect printline by using different memory segments
Hi! I have a system with NIOS and several memory blocks, 2 x On-Chip, SDRAM and SRAM. All of them work well, as long as I use same memory for all segments (.heap, .data, .stack....). As soon a...
12 years agoHi!
Thank you, Sir, for the quick reply. I'm very beginner, so sorry if my questions are stupid. --- Quote Start --- Does your FPGA meet all timing specs? --- Quote End --- How can I find it out? Do I have to use TimeQuestAnalyzer? Never used it to be honest. I even get this critical warning Critical Warning (332168): The following clock transfers have no clock uncertainty assignment. For more accurate results, apply clock uncertainty assignments or use the derive_clock_uncertainty command. and I read something about how to solve it but I don't know where to use the derive_clock_uncertainty command. --- Quote Start --- Have you tried running the Memory tests on the different segments? --- Quote End --- You mean this Memory Test template in the Eclipse IDE? Realy no idea how things work, totaly beginner, sorry once more.:oops: Regards.
