15 years agoincmprehensible error
Hi !! When i compile my programm, I have these errors : --- Quote Start --- Error: Can't pack LABs Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[0]" of type max_...
15 years agoSorry for my confusing post.
What I mean, all variables were created with the same bit number. I tested with 15, 16 and 17 bits, I have the same problem. For a gived value, I was a compilation problem. For another value (same bit number) i have a compilation problem. pletz (http://www.alteraforum.com/forum/member.php?u=1380) => sorry I mixed two test programms for my example. To resume : for the 80Hz value the compilation is ok for "111" but not ok for "101". (It's an example, the true problem appears with a 16 bit signal std_logic_vector).
