15 years agoincmprehensible error
Hi !! When i compile my programm, I have these errors : --- Quote Start --- Error: Can't pack LABs Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[0]" of type max_...
15 years ago --- Quote Start --- Hi !! When i compile my programm, I have these errors : My programm consists to a variable control_2 (std_logic_vector (15 downto 0)) which count up to a constant value . When this value is egal, control_2 is initialized to 0 and count up a new time, etc... The constant can be 4 values defined by the position of a commutator (hardware). Here I don't understand all these errors, and more even if my constant et control_2 is always 16 bits, sometimes i don't have these errors sometimes i have. It depends the value of the constant. An exemple : Here divide_2 is the constant. The values of divide_2 generate or not the compilation errors. Why if for 8000Hz my value is "000000001101101" I have these errors? And why for this case if my value is "000000001111101" I don't have errors...? The compilation is ok and my outpout is ok. Please Help me...:confused: --- Quote End --- Hi, your post is also a little bit confusing. You posted that your compilation isn't successful, but later on you wrote that the compilation and your output is ok ? BTW: What is the width of your signal, 16 bit ? You compare values are 17 bit or 15 bit ??? 11101010011000000 17 bit 011000011010100 15 bit 000010011100010 000000001111101 000000000000001 Kind regards GPK
