JShen23
7 years agoIn Cyclone V, is there other way to implement a transmitter PLL else than using CMU PLL?
In cyclone V, at least 1 receiver channel cannot be used because CMU PLL which serves as the transmitter PLL is implemented by this resource. Is there any other way to implement the transmitter PLL s...
JShen23
7 years agoHi Chee!
I have a look at the design. It is very helpful and solves my question. The top file is very informative.
Thank you very much!
I have one more question regarding the native PHY.
I usually do not use 'phase compensation FIFO' when I use custom PHY, because I connect the low speed parallel clock to the FPGA fabric interface clock/FPGA user-designed logic after the custom PHY. However, in the native PHY IP configuration window, I did not see a place to 'disable' the phase compensation FIFO. Is it always included? Does it do anything at all if I use the low speed parallel clock for FPGA fabric interface clock ?
Thank you!
Jue
CheepinC_altera
7 years agoHi Jue,
Thanks for your update. Glad to hear that you have managed to resolve your issue.
Regarding your latest inquiry on the phase comp FIFO, for your information, it is always there and cannot be disabled. It will compensate for the clock phase different at the core-XCVR interface and would not affect your usage of the low speed parallel clock.
Chee Pin
