17 years agoImproving my NIOS II code to improve speed.
HI, This is my NIOS II code but I think it is not that great becasue it cannot deal with data >200 Hz.
Does anyone have any idea for changes to improve the speed? Thank you very much in advance, do you not know how much this is appericated. # include <stdio.h># include <string.h># include <ctype.h> # include <stdio.h> /* Nichestack definitions */# include "ipport.h"# include "tcpport.h"# include "libport.h"# include "osport.h"# include "altera_avalon_pio_regs.h"# include "myprogram.h"# include "command.h" int OpenSocket(int tcpip_port) { int fd_listen; struct sockaddr_in addr; if ((fd_listen = socket(PF_INET, SOCK_STREAM, 0)) < 0) return TCPERR1; addr.sin_family = AF_INET; addr.sin_port = htons(tcpip_port); addr.sin_addr.s_addr = INADDR_ANY; if ((bind(fd_listen,(struct sockaddr *)&addr,sizeof(addr))) < 0) return TCPERR2; if ((listen(fd_listen,1)) < 0) return TCPERR3; return fd_listen; } void srv_tcpip() { int sock, fd_client, fd_tmp, nfds, status, idx; int len, retval, n_read; fd_set rset, wset, rset_, wset_; struct sockaddr_in incoming_addr; alt_u8 buf[255]; alt_u32 in_data; int rdy = 0, rdy_old = 0; if((sock = OpenSocket(DATA_PORT)) < 0) { fprintf(stderr, "srv_tcpip: unable to open socket\n"); return; } FD_ZERO(&rset); FD_ZERO(&wset); FD_SET(sock, &rset); nfds = sock+1; fd_client = -1; for(;;) { wset_ = wset; rset_ = rset; retval = select(nfds, &rset_, &wset_, NULL, NULL); if(retval < 0) {fprintf(stderr, "srv_tcpip: failure on select\n"); return;} if(FD_ISSET(sock, &rset_)) { len = sizeof(incoming_addr); fd_tmp = accept(sock, (struct sockaddr*)&incoming_addr, &len); if(fd_client == -1) { fd_client = fd_tmp; FD_SET(fd_client, &rset); FD_SET(fd_client, &wset); nfds = fd_client+1; } else { close(fd_tmp); } } else if(fd_client != -1 && FD_ISSET(fd_client, &rset_)) { n_read = recv(fd_client, buf, 80, 0); if(n_read <= 0) { close(fd_client); FD_CLR(fd_client, &rset); FD_CLR(fd_client, &wset); nfds = sock + 1; fd_client = -1; } } else if(fd_client != -1 && FD_ISSET(fd_client, &wset_)) { //IOWR_ALTERA_AVALON_PIO_DATA(RRDY_PIO_BASE, 1); rdy = IORD_ALTERA_AVALON_PIO_DATA(EMPTY_PIO_BASE); if(rdy_old != rdy) { rdy_old = rdy; if(rdy == 0) { in_data = IORD_ALTERA_AVALON_PIO_DATA(READ_PIO_BASE); status = send(fd_client, (void *)&in_data, 4, 0); } } continue; } } } /* Command thread: handle commands from tcpip client */ void cmd_tcpip() { int sock, fd_client, fd_tmp, nfds, status; int len, retval, n_read; fd_set rset, wset, rset_, wset_; struct sockaddr_in incoming_addr; alt_u8 buf[256]; if((sock = OpenSocket(CMD_PORT)) < 0) { fprintf(stderr, "cmd_tcpip: unable to open socket\n"); return; } FD_ZERO(&rset); FD_ZERO(&wset); FD_SET(sock, &rset); nfds = sock+1; fd_client = -1; for(;;) { wset_ = wset; rset_ = rset; retval = select(nfds, &rset_, &wset_, NULL, NULL); if(retval < 0) {fprintf(stderr, "cmd_tcpip: failure on select\n"); return;} if(FD_ISSET(sock, &rset_)) { len = sizeof(incoming_addr); fd_tmp = accept(sock, (struct sockaddr*)&incoming_addr, &len); if(fd_client == -1) { fd_client = fd_tmp; FD_SET(fd_client, &rset); nfds = fd_client+1; } else { close(fd_tmp); } } else if(fd_client != -1 && FD_ISSET(fd_client, &rset_)) { n_read = recv(fd_client, buf, 80, 0); if(n_read <= 0) { close(fd_client); FD_CLR(fd_client, &rset); nfds = sock + 1; fd_client = -1; } else { printf("Received %d bytes\n", n_read); status = do_cmd(buf); status = send(fd_client, (void *)buf, n_read, 0); } } continue; } }No RepliesBe the first to reply
