11 years agoImprove timing using multiple PLL
Hello all,
In device like Cyclone V A9 there are 8 PLL. Generally I generate system clock from one PLL in normal mode but there is a way to improve timings using nearer PLL for some design parts using same system clock? Thank you3 Replies
So just one PLL at time can be used and fitter chose the best?
Usually clock tree is global and if an improvement occurs due to multiple PLLs then it is likely a matter of chance fitting.
I can better compensate remote locations with another PLL in sync with system clock?
