17 years agoImplimenting a NCO Core.
Hi i am learning to use Quartus II, At the moment i am trying to just generate a sin wave for a stratix II board. I have set up the NCO block and got the symbol on the block diagram but i ...
17 years agoCheck the License Setup menu to see if you have the NCO Feature on your license
It should appear as Numerically Controlled Oscillator. But even if you don't have the license, you can evaluate the core using the JTAG. I think there might be something else interfering on your project. How are you checking if the NCO is working? Did you use signal tap?
