17 years agoImplimenting a NCO Core.
Hi i am learning to use Quartus II, At the moment i am trying to just generate a sin wave for a stratix II board. I have set up the NCO block and got the symbol on the block diagram but i ...
17 years agoHello Thiago,
Thank you for your reply. I did the constant with a thing called "lpm_constant"....it's a megafunction symbol. My added signals are still "unknown" after I did the "Analysis and Elaboration". I can set the direction in the Pin Planner after right-click in "Node Properties" as input or output, but they do not automatically. Maybe there is a version/license problem ?? I get no Signal after programming on Cyclone III!
