17 years agoImplimenting a NCO Core.
Hi i am learning to use Quartus II, At the moment i am trying to just generate a sin wave for a stratix II board. I have set up the NCO block and got the symbol on the block diagram but i ...
17 years agoHello Tobias,
Yes, you need input signals to connect to the NCO phi_inc_in but you could use a vhdl module that produces a constant output and connect it to the NCO. In the pin planner you need to run at least an Analysis and Elaboration before you get the correct input and output pins direction ok? Regards Thiago
