15 years agoImplementing ROM - which FPGA to use?
Hi all,
I need to implement 5 look-up tables (for 5 DACs), with a total of ~800Kbits. I built a simple rom (didn't use a mega-function) - an entity with address and data pins and an internal array which has the data hardcoded inside. When I compiled the project I found that the FPGAs logic elements were almost entirely used (98%) but the memory bits weren't used at all. My questions are (sorry if they are too simple :) ): 1. What is the difference between logic elements and memory (in an FPGA)? 1. Why was my code tranlated into logic elements and not memory? 2. Is there a way to use the memory bits for the rom (instead or along with the logic elements) Thanks in advance11 Replies
FPGAs have dedicated blocks for memory (ASIC like sections) that you need to interface your logic fabric to it. It can be done by instantiation through megawizard (recommended for beginners) or inferred by special HDL templates (see Altera site).
