17 years agoImplementing Phase Accumulator in VHDL
Hi, I am currently in the process of designing a Phase Accumulator in VHDL for Altera Cyclone 3 Family. I realise there is an NCO Mega Function in the Altera Library. Can some one explain...
17 years agoBasic NCO operation is very simple to my opinion. Actually it's essential to have a large fractional part in total accumulator bitwidth respectively resolution. Your description is fully correct, just consider a few additional facts:
- the output resolution is the number of bits, that can be used by your design, e.g. an output DAC - a periodic signal is achieved by allowing the accumulator to overflow. This already clarifies, that the most significant bits form the output - a fractional part (the accumulator bits right of the least significant bit going to the output) are required to achieve phase/frequency resolution. You can try by pencil and paper method to generate a very low frequency with a virtual NCO.
