17 years agoimplementing a mux using high impedances
I have many streaming input ports that I want to connect to a single streaming output port. Rather than using a VHDL case or lengthy ifels statement, I was wondering if I could get tricky with...
17 years agoPlease read page 6-46 of the coding guidelines:
http://www.altera.com/literature/hb/qts/qts_qii51007.pdf In addition to kaz and FvM's comments, you really should avoid internal tri-states whenever possible. It's truly a luxury for us that the tools even handle them at all. There is no such thing as an internal tri-state in FPGAs. All you are doing is forcing the compiler to figure out a muxing scheme for you and it may not be as efficient as you doing it yourself. And this sort of coding really doesn't fly in the ASIC design world. Jake
