9 years agoImplementation of VHDL program on FPGA
Hello, I try to implement a simple vhdl program " if the switch button is ON then the led has to be ON" on FPGA using Quartus but it doesn't work means the switch is ON but the led is still OFF. ...
9 years agoHi berkoka,
I would suggest that you run a functional simulation with Modelsim with your codes prior to hardware testing. With this, we can be sure if the codes are working and isolate functional related issue prior to hardware debugging. Best Regards, bfkstimchan (This message was posted on behalf of Intel Corporation)
