16 years agoImage Fusion of 2 video Sensors with DE2-70
Hello, Currently I am looking for a small system that could merge two camera images (IR and visual Image) and show the whole to a display. That's how I found the product "de2-70" from Te...
15 years ago --- Quote Start --- thank you Tricky, for the fusion i would use the formula (A+B)/2, i could also calibrate te 2 video sensors but more i think not. I have choiced the DE2-70 because i can use the 2 Video inputs and the 1 Video out(VGA) for my application, and this board is very flexible for other applications. Now i need to have opinion about this Board and demo example. thank for Help --- Quote End --- hi! i am also working for a similar project with DE2-70 board. i need two video input and one video output for my project want to switch video sources and also display two video frame by frame on the same screen. i used DE2-70_TV demo for the first video source and applied for the second source. And combine these two video blocks. But there is some problems i couldn't solve. In my solution, the two blocks use the same PLL and iTD1_CLK and iTD2_CLK are being switcehed by this PLL . THe blocks are working when i used seperately. But it doesn't work when i combine these two blocks? If you have any improvement in your project can you share with me?
