Im having trouble finding any Cyclone III 3c25 starter kit software files or even factory resets
- 3 years agoFound starter kit package in my archives.
https://www.dropbox.com/s/ke5tsyjwa65tfkw/CIII_Starter_Kit-v7.2.0.exe?dl=0
Thank you for the links, but they aren't quite what im looking for:
1. For example Quartus Prime does not support the board, version 13.1 is the last version that did. (tho i believe i have found a link for that version, and is likely part of what i am looking for, even prior to making this post)
2. While the example files is something im looking for, in general, and i still think some will be useful even across boards, i am explicitly looking for the archived ones (and the reason for making the post), i.e. the ones compatible with my board, and compatible with the quartus version i will likely have to use due to compatibility reasons.
3. This seems useful even if it will be across versions. Thank you.
By enlarge i do not think i have found the factory rest files and examples, i feel i would need, though the links provided thus far; I will still try to look else where, and am hoping someone may still know where i could get them or have a copy lying around.
As for the documents being outdated, yes, in some sense they are, but they are also the latest versions available, at least what i was able to find on the intel site.
