16 years agoIf transceiver not used,should power connected?
I'm designing a pcb with an EP4CGX110 in it.I'am not going to use the transceiver part, so can i just leave the VCCL_GXB VCCH_GXB VCCA_GXB and the differential IO not connected? And is there a...
16 years agoI guess, it's exactly specified in the datasheet.
Previous GXB devices (e.g. Arria) has these requirements: - Power all supply voltages - Connect all unused differential inputs to a (common) pair of weak pull-up/pull-down resistors It's most likely correct for Cyclone IV, too.
