10 years agoIf I can use FPGA to realize the goal of ultra-high speed counts
I want to use the FPGA to realize the goal of high speed counter,which can count 10G pulse per second. Would you please tell me which series of the altera can make it ? How to realise t...
10 years agoGenerally the Stratix V series transceiver can run at 10Gbps data rate and above. Note that this is only at transceiver. The core speed would be much lower. You can check the datasheet for detail.
