16 years agoi2c problem
Hello. I made a i2c to configure in sidetone the audio codec on de2 bord. It seems i may encounter two problems: 1. The Sda line changes the state on the scl='1' insted of scl='0', so the ...
16 years ago --- Quote Start --- Hello. I made a i2c to configure in sidetone the audio codec on de2 bord. It seems i may encounter two problems: 1. The Sda line changes the state on the scl='1' insted of scl='0', so the i2c is in start state always. 2. The sda is pulled up to vdd. How can i transmit 0 an 1 to the audio codec? Dose altera provide any solutions for these problems? PS:I'm working in VHDL! --- Quote End --- I have encountered similar problems in SMBus(a subset of I2C) last year. I suggest you check your state machine deliberately to meet the I2C timing request.
