14 years agoI want to use different oscillator
Hi I am using MAX II Micro Kit. In my application i need to use 32.768Mhz oscillator. Can i replace 50 Mhz oscillator with 32.768 Mhz? If i change it, will i have programming problems? how ca...
14 years agoI coincudencely found the problem. I did not change anything as hardware but I changed the folder name because it has space in it. I can program it now. I found this solution by searching something else for modelsim altera.
